GreenVTi991 Posted May 4, 2012 Author Share Posted May 4, 2012 Thanks noodels. I will post up some before, during and after pics! Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted May 7, 2012 Author Share Posted May 7, 2012 Suspension fitted. Test drive complete. Transformed the car?YES! Oh my god yes! If there are any MB6 owners reading this with standard suspension - get some MG ZS 180 suspension NOW. As others have said before - its how it should have been from the factory!I found it all very straightforward to fit but it was made easier with my good mate Daz helping me. We had a slight hiccup when trying to get the n/s/f strut out as Daz stood on the lower wishbone which popped the ARB link off and the halfshaft popped out too! One unforeseen issue was the rear ARB. Tried fitting it only to find out holes on the mounting brackets wouldnt line up with the ARB mounts. Luckily the chap I bought the suspension off agreed to me collecting the MG brackets off him ASAP. Once I had the MG brackets on the ARB went on a treat.Next on the to-do list is tracking and tyre pressures. Quote Link to comment Share on other sites More sharing options...
noodels Posted May 7, 2012 Share Posted May 7, 2012 another satisfied customer Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted May 7, 2012 Author Share Posted May 7, 2012 I hear you noodels pics will be taken once I've cleaned my car as it is filthy! Unfortunately I didn't take any during pics Quote Link to comment Share on other sites More sharing options...
EmZvr Posted May 7, 2012 Share Posted May 7, 2012 Suspension fitted. Test drive complete. Transformed the car?YES! Oh my god yes! If there are any MB6 owners reading this with standard suspension - get some MG ZS 180 suspension NOW. As others have said before - its how it should have been from the factory!All the above I have just found to be true! Aah I'm starting to think that this set up is not so good for my MB3 I didn't felt such a difference, in fact changing to 26mm front arb and mg zs rear one was ten times more worth it. But can't understand why, the weight difference in MB3 and MB6 is not so big:1.5i LS VTEC with SRS, ABS and A/C M/T 1,191 kg 2,626 lbs1.8VTi VTEC with SRS, ABS and A/C M/T 1,281 kg 2,824 lbsIs there any one else on the forum with MB2/3/4 and MG ZS Spings and shocks ? Quote Link to comment Share on other sites More sharing options...
noodels Posted May 7, 2012 Share Posted May 7, 2012 consider front axel mgzs180 =940 kgs,mb6 =880kgs, Quote Link to comment Share on other sites More sharing options...
EmZvr Posted May 7, 2012 Share Posted May 7, 2012 I see, so MB6 is already at the edge. But according to the internet B18 = 350lbs, 88-95 D15 engine/trans = 300 lbs Sounds like the difference between B and D series is not so big or is the info inccorect ? So am I really the only one nonVTI with MG ZS suspension Quote Link to comment Share on other sites More sharing options...
GreenVTi991 Posted May 14, 2012 Author Share Posted May 14, 2012 I fitted the MG front ARB yesterday as one of the original drop links popped apart. It was a straight swap and the drop links are a solid metal bar with four rubber bushes.I definitely believe my car is turning in sharper and isn't rolling on the front. Quote Link to comment Share on other sites More sharing options...
wezza9 Posted May 14, 2012 Share Posted May 14, 2012 i thought the front ARB is same size but a different design on the mg as ours but its the same as a DC2 ??????? if its different have you got pics and sizes please ??? Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted May 14, 2012 Share Posted May 14, 2012 i thought the front ARB is same size but a different design on the mg as ours but its the same as a DC2 ??????? if its different have you got pics and sizes please ???x2 pics?? Quote Link to comment Share on other sites More sharing options...
