Mr Brown Posted May 5, 2014 Share Posted May 5, 2014 Result !!! Quote Link to comment Share on other sites More sharing options...
Smitty_Works Posted June 13, 2014 Share Posted June 13, 2014 I am going to have to try this a lil later on. I was driving to get my car registered today and the damn SRS light came on. I keep my service connector in the glove box just for these occasions. I got in line to get my car checked and tried to reset it 5 times. Light went out but came back on as soon as I turned the steering wheel just a lil bit. So I am going to try and disconnect the steering wheel and reset the light after a few errand I take care of. Quote Link to comment Share on other sites More sharing options...
Krzys Posted June 13, 2014 Share Posted June 13, 2014 You might have a damaged ribbon inside for the SRS? Hopefully you'll have it fixed/set fire to in no time! Quote Link to comment Share on other sites More sharing options...
Smitty_Works Posted June 13, 2014 Share Posted June 13, 2014 On 6/13/2014 at 10:52 AM, Krzys said: You might have a damaged ribbon inside for the SRS? Hopefully you'll have it fixed/set fire to in no time! okay so I checked everything out and I re-did the reset trick and the light still stays on. I am not 100% sure but I think its not my drivers air bag or reel. I did some looking on the internet and found out that the European Aerodecks don't have standard OBD2 connectors like in the states. I was trying to jump the 4 and 9 ports to get the SRS codes. Then I found out you just use the regulars service port to get the codes. I did that and I came up with 2-1, 2 short and one fast:2-1 & 2-2 open circuited In Passenger's Air Bag Inflator So now I am gonna try and disconnect that and try again. Quote Link to comment Share on other sites More sharing options...
