srs light on (help please)
shebabby
  • 1 month later...
I am going to have to try this a lil later on. I was driving to get my car registered today and the damn SRS light came on. I keep my service connector in the glove box just for these occasions.
I got in line to get my car checked and tried to reset it 5 times. Light went out but came back on as soon as I turned the steering wheel just a lil bit.
So I am going to try and disconnect the steering wheel and reset the light after a few errand I take care of.
You might have a damaged ribbon inside for the SRS? Hopefully you'll have it fixed/set fire to in no time!
okay so I checked everything out and I re-did the reset trick and the light still stays on. I am not 100% sure but I think its not my drivers air bag or reel. I did some looking on the internet and found out that the European Aerodecks don't have standard OBD2 connectors like in the states. I was trying to jump the 4 and 9 ports to get the SRS codes. Then I found out you just use the regulars service port to get the codes.
I did that and I came up with 2-1, 2 short and one fast:
2-1 & 2-2 open circuited In Passenger's Air Bag Inflator
So now I am gonna try and disconnect that and try again.
