stevovti-s Posted May 19, 2012 Share Posted May 19, 2012 Im just trying to figure out as many problems before I start the work as possible, and the next thing that's puzzling me is if I fit the B18C6, the first 3-6 months I will be running it on a standard UK DC2 ecu. Does this mean I will need the ignition barrel to go with the ecu? Or will it be just a case of getting the existing key reprogrammed to the new ecu? Also, just to confirm, will a uk spec B18C6 and Ecu be a simple plug in and play into the existing MB6 loom? This is my first attempt at an engine swap, so I'm trying to learn as much as possible before I start. ThanksSteve Quote Link to comment Share on other sites More sharing options...
beastgtir Posted May 20, 2012 Share Posted May 20, 2012 you can just use a JDM DC2 ecu, that will solve your problems regarding the immobiliser/coded key.or a chipped p28/p30 ecu with a generic map, or you can get a road/rolling road tune map put on it. Quote Link to comment Share on other sites More sharing options...
simpo Posted May 20, 2012 Share Posted May 20, 2012 Wouldn't he need a jumper harness? Quote Link to comment Share on other sites More sharing options...
beastgtir Posted May 21, 2012 Share Posted May 21, 2012 yes, are they different obd? both from similiar years though? unless he goes for a p28/30 ecu which is obd1, conversion harnesses arent too dear either way. Quote Link to comment Share on other sites More sharing options...
simpo Posted May 21, 2012 Share Posted May 21, 2012 I thought the c6 was obd2 could be wrong thou Quote Link to comment Share on other sites More sharing options...
johngreen537 Posted May 21, 2012 Share Posted May 21, 2012 simpo said: I thought the c6 was obd2 could be wrong thouI'm fairly sure it's actually an ODB2 ECU, but the car uses a ODB1 harness / wiring loom. Quote Link to comment Share on other sites More sharing options...
stevovti-s Posted May 21, 2012 Author Share Posted May 21, 2012 So if I get a JDM P73 ecu, that will run the engine and I won't need to change any keys or ignition barrel? The jumper harness, do you mean OBD2 to OBD1 conversion?Steve Quote Link to comment Share on other sites More sharing options...
johngreen537 Posted May 21, 2012 Share Posted May 21, 2012 Pretty sure, yes mate. Search for P73, I remember a good while back someone else did the P73 thing! Quote Link to comment Share on other sites More sharing options...
johngreen537 Posted May 21, 2012 Share Posted May 21, 2012 johngreen537 said: Pretty sure, yes mate. Search for P73, I remember a good while back someone else did the P73 thing!Slightly wrong there! Looky here:viewtopic.php?f=62&t=6144&hilit=p73P72 is Direct swap but you really need it socketing and a new map. P73 doesn't let you use IAB's from what I remember, so you'd need to ditch the intake manifold etc.The differences between the plugs on the ECU are minor, so a stanley knife will make it work http://cars.homenetcs.co.uk/honda-civic ... ns-ecu.htm Quote Link to comment Share on other sites More sharing options...
stevovti-s Posted May 21, 2012 Author Share Posted May 21, 2012 I'm going to be running a B18C6 motor though, so shouldn't the P73 work fine with that engine? Quote Link to comment Share on other sites More sharing options...
