radiator fan
Nabil83
hi peeps, not sure how long it takes for a radiator fan to kick in on an MB2 have serviced it few days ago, engine running like a clock temp indicating how it should, after washing it yesterday I turned it on from cold and let it run for like 10 to 15 mins waiting for the fan but no luck is this normal ???
the service its just had will make it run cooler a bit so dont worry mate :)
if you want to check if the fans working hold the revs at about 2000 rpm untill the fan kicks in should take about 10 to 15 minutes .
cheers for the tip mate ! :)
