airbag
simpo
just wondering if there is some way of turning the passanger side airbag off as i av my little one in the front and its not safe with it on. any info would be great
The only way you can turn it off is to unplug the airbag remove the glovebox and you will see the wire going to it . But is will put the airbag light on and stop the other safty systems working . Rich.
I think the aftermarket steering wheel people wire a resistor where the airbag used to be, to keep other systems working and the other airbag working.
I'm sure the same would apply to the passenger airbag but have no idea how or what rating of resistor to use.
The resistor tricks the system into thinking the airbag is still connected.
