joelufc20 Posted November 21, 2012 Share Posted November 21, 2012 hello, is this in the box or on the pipe as want to put an induction kit into mine Quote Link to comment Share on other sites More sharing options...
simpo Posted November 21, 2012 Share Posted November 21, 2012 Does it have one? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted November 21, 2012 Share Posted November 21, 2012 Don't think it has one. Only the full Obd2 civics like the facelift eks have one. Quote Link to comment Share on other sites More sharing options...
joelufc20 Posted November 25, 2012 Author Share Posted November 25, 2012 how does the ecu balance the mix then on this engine without a airflow meter unless its pre-determined Quote Link to comment Share on other sites More sharing options...
Boney M Posted December 3, 2012 Share Posted December 3, 2012 My 96 obd 1 D14A2 Ma8 has a Denso MAP (manifold absolute pressure) sensor on top of the throttle body. The ecu uses this along with other sensors such as coolant temp, oxygen sensor (lambda) and vehicle speed sensor etc. So in answer to your question yes most if not all 1.4 civics have an airmass meter of sorts and yes you can fit an induction kit as the sensor is located after the throttle butterfly and therefore will take into effect any increase in airflow and inform the ecu. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted December 3, 2012 Share Posted December 3, 2012 Yeah what he said. MAP sensor as opposed to MAF. Located on inlet manifold Quote Link to comment Share on other sites More sharing options...
joelufc20 Posted December 8, 2012 Author Share Posted December 8, 2012 cheers guys you gotta love the sohc 1.4 d engine its bullet proof such a simple well built unit Quote Link to comment Share on other sites More sharing options...
