Door indicator warning light issue!
Civicsport5
The red open door indicator light on my mb3 dash is constantly lit any ideas what it might be I've tried opening all the doors and closing them again including the boot and bonnet and it won't go out even when I start driving the car!
Is the sensor the L shaped sliding thing on the door frame?
Any help is most welcome :)
  • 1 month later...
My drivers door one keeps turning on and off when i open the door. I need to fix it really as its annoying!
Just open and clean the switch, but don't lose the returning spring :D Take fine sandpaper (400-800, whatever) to clean that green oxidised stuff away from those contacts so contacts are clear metal again. All black and greenish stuff are things you wan't to get rid of.
After cleaning, good coat of grease made for electric connections to protect those contacts from moisture and it should be fine for years again.
