ryan.. Posted February 8, 2013 Share Posted February 8, 2013 remember, fitting the oil filter should only be hand tight Quote Link to comment Share on other sites More sharing options...
RobE84 Posted February 8, 2013 Author Share Posted February 8, 2013 Thanks guys... only engine mods on this is a tenzo r air intake. What I cant understand was IABs was working last time I drove it hard. HAve my service kit. What oil do you guys use. Was thinking castrol but heard some bad rumours... bearing in mind this service will probably see 2.5 - 3k km across europe at high revs.... Quote Link to comment Share on other sites More sharing options...
noodels Posted February 8, 2013 Share Posted February 8, 2013 i use magnatec semi, reminds me may be a halfords offer on soon Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted February 8, 2013 Share Posted February 8, 2013 RobE84 said: Thanks guys... only engine mods on this is a tenzo r air intake. What I cant understand was IABs was working last time I drove it hard. HAve my service kit. What oil do you guys use. Was thinking castrol but heard some bad rumours... bearing in mind this service will probably see 2.5 - 3k km across europe at high revs....Is the tenzo long arm or short, have you tried cleaning it. Oil wise use the best you can afford but magnatec is fine that's what I've used a couple of times now and it's perfectly happy. Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted February 8, 2013 Share Posted February 8, 2013 I have just used Motul and it seems very good, also we get discount Quote Link to comment Share on other sites More sharing options...
marko Posted February 10, 2013 Share Posted February 10, 2013 steveolkinevel said: Pulling the vacume hose of the iabs wont realy do any thing, apart from maybe make it run lean, pointless unless you alter the map to suit the iab delete, you rill only make the same power as the fueling is set to increase at 5800 when the iabs open,If you want a bigger "kick" or noticable change at 4.5k put a 4-1 mani on! Massive noise difference!i can vouch for this ive ran my car with iabs on and off a few different times, now vtec note is very aggressive and loud when the iabs of open all the time, but if its wet and i my foot down in second it hit the vtec no pull just loud noise and then around 6k when the iabs would be fully open my engine goes sick and spins the wheels up to death. so in short if your gunna delete your iabs then you just gotta keep you revs above 6k easy Quote Link to comment Share on other sites More sharing options...
marko Posted February 10, 2013 Share Posted February 10, 2013 also my fav oil filter remove tool is a hammer and screwdriver a mans tools Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted February 10, 2013 Share Posted February 10, 2013 marko said: steveolkinevel said: Pulling the vacume hose of the iabs wont realy do any thing, apart from maybe make it run lean, pointless unless you alter the map to suit the iab delete, you rill only make the same power as the fueling is set to increase at 5800 when the iabs open,If you want a bigger "kick" or noticable change at 4.5k put a 4-1 mani on! Massive noise difference!i can vouch for this ive ran my car with iabs on and off a few different times, now vtec note is very aggressive and loud when the iabs of open all the time, but if its wet and i my foot down in second it hit the vtec no pull just loud noise and then around 6k when the iabs would be fully open my engine goes sick and spins the wheels up to death. so in short if your gunna delete your iabs then you just gotta keep you revs above 6k easy lol thats one way to look at it! Quote Link to comment Share on other sites More sharing options...
RobE84 Posted March 4, 2013 Author Share Posted March 4, 2013 quick update, been out and checked IABs doesn't appear to be working... i have checked with engine on and off and the little lever on the base of the diaphram doesnt budge at all...what creates the vacuum to operate this or how can i try force a signal to this to see if its electrical or mechanical fault??? Quote Link to comment Share on other sites More sharing options...
