jdm p72 ecu doesn't fit
vtismill
I have just put a b18c engine out of an integra sir into my vtis and got the jdm p72 ecu too, I was under the impression it went straight in but the plugs are different? Thought they were both obd1 style plugs? Also how do I bridge the pins for vtec to work or does that not matter since its no longer b18c4??
It's baffling me a bit any help would be appreciated thanks james
  • Replies 22
Top Posters In This Topic
  On 6/24/2013 at 4:38 PM, knight said:
P72 is plug and play with the exception of shaving a bit on one of the plugs on the loom irc
Can't u get 2 types of p72 ecus for it to be obd1 u would need to get it off the early teg?
yes late type is obd2a irc so you need the obd1 early type, forgot about that thanks simpo! :wink:
put a photo up of the ecu (bit where the code is and plugs are) sounds like you bought the wrong one (late type obd2a)
