Roylewaa Posted October 12, 2013 Share Posted October 12, 2013 As title, since changing my thermostat I've had a bubbling and gurgling sound coming from the heater matrix on mainly cold startingI'm guessing theyres still some air in there from the stat change, as it didn't do this beforeIs they're a good method of getting this air out without to much hassle?Coolant is pretty much up to the neck inside the rad and expansion tank is on the max, levels have not changed since the stat was changed about a month ago, temp gets up to just below half now and stays there no matter what which points that it was originally the stat at fault before. heaters are also nice and hot Cheers for any advice:) Quote Link to comment Share on other sites More sharing options...
marko Posted October 12, 2013 Share Posted October 12, 2013 Take the cap off the expansion tank and just let the car run for a bit should get the bubbles out eventually Quote Link to comment Share on other sites More sharing options...
simpo Posted October 12, 2013 Share Posted October 12, 2013 I would take the rad cap off and run it Quote Link to comment Share on other sites More sharing options...
Roylewaa Posted October 12, 2013 Author Share Posted October 12, 2013 Thanks chaps, il give that a go:) Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted October 12, 2013 Share Posted October 12, 2013 Also, Obviously keep heater set to hot then motivate the air to move with a bit of squeezing of the hoses going into matrix. Quote Link to comment Share on other sites More sharing options...
Roylewaa Posted October 12, 2013 Author Share Posted October 12, 2013 Will do Quote Link to comment Share on other sites More sharing options...
