KiNK43 Posted December 29, 2013 Share Posted December 29, 2013 Front knuckles. Rear trailing arms. Rear upper arms are the same across 92-00But ek uses longer pressed rear lca. The front upper arms are completely different. The subframe, rack and column are different. And the front lower arms are again like pressed and welded rather than cast like ours. And mount differently to the sub frame 1 Quote Link to comment Share on other sites More sharing options...
Grant Posted December 29, 2013 Share Posted December 29, 2013 Front knuckles. Rear trailing arms. Rear upper arms are the same across 92-00But ek uses longer pressed rear lca. The front upper arms are completely different. The subframe, rack and column are different. And the front lower arms are again like pressed and welded rather than cast like ours. And mount differently to the sub frameGreat info mate thanks!! So do you know whether coils from an EK would go on?? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted December 29, 2013 Share Posted December 29, 2013 Yeah they work fine.Ms have a weird rear lca. It's same as eg dc2. But has ek middle bush. So yeah ek shocks fit. 1 Quote Link to comment Share on other sites More sharing options...
Grant Posted December 29, 2013 Share Posted December 29, 2013 Yeah they work fine.Ms have a weird rear lca. It's same as eg dc2. But has ek middle bush. So yeah ek shocks fit.HSD's will be going on then Quote Link to comment Share on other sites More sharing options...
