My MB6 - bought a deck!
marv
Removed the pcv valve and it was still clean and working. Ran with it disconnected and made no difference :( got a bit p**sed off so started stripping it again. Removed rocker cover and found this........
FA7E4EAC-B212-4B2B-AEC2-72DC83A08035_zps
C89DECD2-F40C-4135-80D9-0099B064E7D5_zps
Wtf? Think I would have noticed this before!dont know how it's happened. Now need to try a look at options. Don't know if I could get it welded to block it off or going to need to source a new head.
Yup it's a hole :( don't know if I can just get it blocked and welded or if il have to get another head. God knows how it happened.
I'm sure its just a casting hole. Its not broken or anything.
I would imagine if it was closed you would have a puddle of oil sat there.
I looks like it's broken as there's rough uneven surface/break. Not sure if it's allowing oil into the combustion chamber?
Honestly dude its normal, I will try getting you a pic.
WHat is the car actually doing?
Thanks! Appreciate any input I can get ATM.
Basically burnt a valve,had 2 valves replaced,head skimmed,new stem seals fitted, refitted it and it's smoking worse than before!like all the time. Removed my new 80 mile old spark plugs and no 3 and 4 are covered in oil! Can see oil on top of the pistons. The valves went on no3 and the rest were all ok!
