How do I install fog lights?
h4mza
can not say if those will fit neat but they do look like they will (there is a thread linking to a nice set that fit for not much more money)
Re fitting.. If as you say your car does not have fogs then the plug for them in the loom will NOT be present..This has been discussed on here before a few times and each time we draw the conclusion that the easiest way is for you to wire them in yourself from bumper to switch adding in necessary fuse etc..
im sure there will be a how to on youtube and as you are not running it through the loom any car will be the same principle
This one: http://civic5.com/forum/index.php?/topic/8320-replacement-front-fogs-aftermarket/
They look very similar to the ones in your link.
