onejdmcivic1984 Posted July 7, 2014 Share Posted July 7, 2014 Had a MOT a few months back and the only advisory on the sheet was 'Nearside Wheel Bearing showing signs of play'Recently I've noticed a screech which is intermittant resounding from a wheel.What is required to fix said problem above and is it related to the noise coming from the wheel.I start my new job in Domiciliary Care and will be driving a lot so wanna make sure car us safe to use Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 7, 2014 Share Posted July 7, 2014 Intermittent how? General driving? Under braking? Cornering? (Left? Right) Few things I would check, jack the car up and see how much play is in the offending wheel when you wobble it holding at 12 and 6/9 and 3 o'clock positions with your hands. Might be worth taking the wheel off and seeing what state the pads are in. 1 Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted July 7, 2014 Author Share Posted July 7, 2014 Hmmm I will check but I think the steering is off slightly. I assumed it was alignment but it wasn't Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 7, 2014 Share Posted July 7, 2014 I meant car wheel not steering wheel Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted July 7, 2014 Author Share Posted July 7, 2014 How much is a bearing? Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 7, 2014 Share Posted July 7, 2014 Which one is it you need? Front or rear? Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 7, 2014 Share Posted July 7, 2014 Rears are a big bill! Quite a large part!It's the whole hub for the rear isn't it? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted July 7, 2014 Share Posted July 7, 2014 90 quid for a rear. 30 quid for a front. 1 hour labour for the rear.2 hours labour for front.ish? Quote Link to comment Share on other sites More sharing options...
onejdmcivic1984 Posted July 7, 2014 Author Share Posted July 7, 2014 Just checked and this is full advisory:'Front nearside wheel bearing shows signs of play's Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 7, 2014 Share Posted July 7, 2014 There you go mate.If you need a garage you can trust the one next door to my work is where my mc2 goes.Sounds like a plan there! Quote Link to comment Share on other sites More sharing options...
