xchipx Posted August 13, 2014 Share Posted August 13, 2014 Hi everyone , can you help? My 2000 civic has brake drums on the rear, cant see an abs relay box near the air filter and there are no abs lights on the dashboard that I can see. Do you think its a non abs model?I need to buy a wheel bearing asap and needed to know for that reason. Im guessing the bearing/hub is the same for drum brakes as discs?RegardsMark Quote Link to comment Share on other sites More sharing options...
Krzys Posted August 13, 2014 Share Posted August 13, 2014 From what you said I get the impression that it does not have ABS. Quote Link to comment Share on other sites More sharing options...
DAVEMB2 Posted August 13, 2014 Share Posted August 13, 2014 If there is no lights on dash then I would say no Quote Link to comment Share on other sites More sharing options...
xchipx Posted August 14, 2014 Author Share Posted August 14, 2014 Okay thanks for confirming guys, managed to jack the car up and have a look and there are no wires coming from the rear brake area, and also made sure no abs ring on the hub, so yeah defo no abs it seems.Thanks 1 Quote Link to comment Share on other sites More sharing options...
