nathan123487 Posted January 4, 2015 Share Posted January 4, 2015 ive found a thread on here that i couldnt reply to so i had to make a new one basically im getting a set of these clocks later and im wondering what i will need to do to recalibrate them so my speedo and revolutions are correct ? the milage on them is the same as my existing milage Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 4, 2015 Share Posted January 4, 2015 Which thread was it chap? Might be able to make it work again. Quote Link to comment Share on other sites More sharing options...
nathan123487 Posted January 4, 2015 Author Share Posted January 4, 2015 Which thread was it chap? Might be able to make it work again.http://civic5.com/forum/topic/2773-mb3-mb6-instrument-cluster/ Quote Link to comment Share on other sites More sharing options...
nathan123487 Posted January 4, 2015 Author Share Posted January 4, 2015 it says here about recalibration... where can i do this properly if anyone knows i dont fancy moving the needles about maybe the scale of the numbers is going to cause an issue ? Quote Link to comment Share on other sites More sharing options...
Chandler Posted January 4, 2015 Share Posted January 4, 2015 i would've thought it would've been the same. plug and play :/ Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 4, 2015 Share Posted January 4, 2015 I've set that thread to unarchive, should be active soon. Quote Link to comment Share on other sites More sharing options...
Chandler Posted January 4, 2015 Share Posted January 4, 2015 You gotta dig it up? Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 4, 2015 Share Posted January 4, 2015 I did! It's working now! Quote Link to comment Share on other sites More sharing options...
nathan123487 Posted January 4, 2015 Author Share Posted January 4, 2015 Yea... they were plug and play in the end calibration is slightly more out than the ones I took out sat nav usually said 67 at 70 on the clocks ... with these it says 65 so nothing to worry about Quote Link to comment Share on other sites More sharing options...
Krzys Posted January 5, 2015 Share Posted January 5, 2015 At least they won't get you into trouble! Quote Link to comment Share on other sites More sharing options...
