Bri Posted March 21, 2010 Share Posted March 21, 2010 Would putting a decat in effect emmissions test on an NCT test, MOT equivalent?Cheers. Link to comment Share on other sites More sharing options...
FlunkyVTEC Posted March 21, 2010 Share Posted March 21, 2010 Putting a decat on your car would normally mean MOT (or similar test) failure. A lot of people drive around with a decat and switch to a cat temporarily for the MOT or they happen to know a friendly tester .Another alternative is getting a high flow cat. They aren't road legal in most countries (like decats) but it would be really tough luck if they find out. These will however get you through the MOT if they're warm enough. They will however have slightly less performance increase compared to a decat but save you from switching once a year. Link to comment Share on other sites More sharing options...
Bri Posted March 21, 2010 Author Share Posted March 21, 2010 Cheers for the Info, I think it wud be worth it, just to decat it. What one wud ye recommend for theMB6? Link to comment Share on other sites More sharing options...
jalesi2001 Posted March 21, 2010 Share Posted March 21, 2010 Something like this mate, then you can get the eBay manifold and not worry about having the flange cut off and re-positioned! http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT Link to comment Share on other sites More sharing options...
Bri Posted March 22, 2010 Author Share Posted March 22, 2010 Wud I notice difference in performance, by putting this on?Bri Link to comment Share on other sites More sharing options...
FlunkyVTEC Posted March 22, 2010 Share Posted March 22, 2010 I still have my OEM cat so I can't give any first hand experience but from what I've read putting a decat on will give some performance increase. It should make a bigger difference once you've also changed the header and your exhaust. The exhaust system is only as good as it's most restrictive area. Link to comment Share on other sites More sharing options...
Bri Posted March 25, 2010 Author Share Posted March 25, 2010 So If i got the decat, what header and manifold wud I need to or wud you recommend to get with this? Link to comment Share on other sites More sharing options...
FlunkyVTEC Posted March 25, 2010 Share Posted March 25, 2010 I'd say a 4-2-1 header is best if your car is lowered as it has more ground clearance then a 4-1. What make & type to get all depends on your budget and what type of performance you want (top end power vs. midrange) Link to comment Share on other sites More sharing options...
Bri Posted March 25, 2010 Author Share Posted March 25, 2010 I'd probably go for mid range power with an average budget, so what wud ye recommend?What do you think of this on ebay.http://cgi.ebay.com/ebaymotors/96-00-HO ... ccessoriesCheers. 1"£££$££" Link to comment Share on other sites More sharing options...
simpo Posted March 27, 2010 Share Posted March 27, 2010 dont think that would be any gud as the collecter is 2.5in correct me if i am wrong. also make sure you get a decat that is adjustable as my manifold was about 2-2.5 ins to short lucky enough i had an ajustable one Link to comment Share on other sites More sharing options...
