  • 0
Headlight indicator bulb?
h4mza
Question
I got pulled over the other day because my indicator bulbs aren't amber but white/yellowish due to dechromed and deoranged headlights. The cop however let me off and said I need to get it sorted asap. So now I'm looking for proper amber indicator bulbs but don't know which ones fit. I took my old one out and it says Osram 7506 12V P21W.
I searched on eBay 7506 and P21W but I get results for LED bulbs which I don't want because they will hyperflash.
Can someone help me find the right ones for a good price please, thanks.  :-)
  • 0
If you are deoranged no point in putting orange bulb back, right ? You need bulbs P21W and some call it BA15S but they are very hard to be found (the not orange ones at least)  :( My advice is use the more popular PY21W or BAU15S and shave one of the notches. Mine are like that and it works great.
About bulbs I recommend Osram Diadem. They have a nice rainbow effect and they are proper amber and very bright. I DON'T recommend Osram diadem chrome, I now have them and they are yellow when lit, not amber at all.
  • 0
  On 2/10/2015 at 9:18 PM, ammarbm said:
If I remember correctly I had these ones in my mb2 as the headlights were detangoed and they worked fine for me.. Looked amber as well
Forgot to paste the damn link lol
http://pages.ebay.com/link/?nav=item.view&id=371153003534&alt=web
  • 0
  On 2/10/2015 at 8:03 PM, h4mza said:
Thanks @Chandler
@EmZvr I got these BAU15S bulbs when I first dechromed my headlights like a year ago but they never fitted because the pins wasn't opposite. Might find them and shave one pin and see if they fit without popping out.  :-)
Do it. I'm driving with a shaved pin for 4 months now without a problem.
  • 0
Thanks all I've got a another problem now. The driver side headlight indicator is hyper flashing because the tail light bulb doesn't indicate. The passenger side is ok. I swapped the bulb over and it doesn't work on driver side tail light indicator but works on passenger side. Also same problem with reverse light, driver side doesn't work but passenger does. I'm confused what could the problem be? I do have the JDM tail light mod so wires are tampered with but I'm sure I did a good job with connecting them. I don't think it be the fuse because if it was then both tail lights wouldn't work. Also a few weeks ago I noticed the driver side reverse light was less bright then passenger side then soon it stopped working. Anyone can help?
Answer this question...
