mc2 diagnostic plug
tom2311
thanks mate! there ia 2 plugs there, aparently the one with two connectors has 2 be bridged but all i want to do is clear a trouble code, do i just plug the computer on the other plug and ignore the one with two connectors?
If you just wanna clear your codes, you can pull out the ECU and back-up fuses out of the under bonnet fuse box for more than 10 secs, that should do it, or if you have equipment that will talk to a Honda ecu, then yeah, connect it to the 5 pin, thats what we do in the dealers!! ;) Hope this helps! 8-)
