Angeldesign Posted April 20, 2015 Share Posted April 20, 2015 Hi guys, how are you doing? I have an issue with my car: its a '97 MB3 with a full d16y8 swap and greddy turbo. I have it tuned (badly) with hondata s300v2 . I was learning and practicing with the ecu before going to a dyno/tune shop and I discovered that I can get the base timing I want. Ive tried to set the base timing with the hondata feature, either 12 (supposed Y8 BTDC) or 16, but Im always far from it even rotating the distributor to both sides.BTW, The cam belt is properly installed, there is no theeth off or such things. I have the distributor rewired, but I dont remember if the guys who do the swap used the Y8 or the Z8 distributor. ¿Wich one should I been using? ¿are they compatibles? Thanks in advance!!! oh! this is my car: https://www.facebook.com/media/set/?set=a.309988735795654.1073741830.306427939485067&type=3 Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted April 20, 2015 Share Posted April 20, 2015 Distributor should be compatible. Which cylinder are you using for timing light? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted April 20, 2015 Share Posted April 20, 2015 Car looks great btw! Quote Link to comment Share on other sites More sharing options...
Angeldesign Posted April 20, 2015 Author Share Posted April 20, 2015 Distributor should be compatible. Which cylinder are you using for timing light? Cyl 1. Thanks! Quote Link to comment Share on other sites More sharing options...
Angeldesign Posted April 21, 2015 Author Share Posted April 21, 2015 Anybody else know how to solve it? Quote Link to comment Share on other sites More sharing options...
noodels Posted April 21, 2015 Share Posted April 21, 2015 Have you bridged the service plug wrong pulley dizzy cam pick up 180 deg out<if thats possible>find tdc and mark your own tdc on pulley or ask someone else 1 Quote Link to comment Share on other sites More sharing options...
EmZvr Posted April 22, 2015 Share Posted April 22, 2015 D15Z8 / D16Y8 dizzy, it shouldn't matter which one you use. It is normal to not be able to reach 16 degrees BTDC. For your engine you need 12 degrees BTDC and you should be able to get them without a problem. @noodels, I've read this in the manual but have you got an idea how exactly bridging the service plug helps or what it does ? My car was timed without bridging the plug and everything is fine. Quote Link to comment Share on other sites More sharing options...
Angeldesign Posted April 22, 2015 Author Share Posted April 22, 2015 Yeah, I dont need to get 16 BTDC, need to get 12 BTDC.No need to bridge the service plug with the hondata "set timing" feature.All the pulleys are from Y8 so thats not the problem.Is not possible to have the dizzy 180º rotated without open, disassemble and modyfy internals to do that. Someones says that they had to modify the distributor holes to rotate a bit more and reach 12 BTDC. Quote Link to comment Share on other sites More sharing options...
EmZvr Posted April 22, 2015 Share Posted April 22, 2015 I had to modify my distributor holes on my D15Z8 but to reach 16 degrees. 12 degrees BTDC shouldn't be a problem at all. Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted April 22, 2015 Share Posted April 22, 2015 @EmZvr The bridge service plug stops stock ecu making adjustments while manually set ignition timing 1 Quote Link to comment Share on other sites More sharing options...
