Viltor Posted September 3, 2015 Share Posted September 3, 2015 Hello everyone, 2 or 3 months ago, I noticed when Im shifting from 1st to 2nd and 2nd to 3rd I notice sometimes some friction. is that normal ? Most of the time its 1st to 2nd and it happens mostyle at low rpm, like 1500rpm or 2000 rpm, is that normal ? someone noticed that ? Thanks Quote Link to comment Share on other sites More sharing options...
0 Krzys Posted September 10, 2015 Share Posted September 10, 2015 Yeah I don't think a short shifter will cure your problem. Quote Link to comment Share on other sites More sharing options...
0 Jayhoath83 Posted September 10, 2015 Share Posted September 10, 2015 It could be a slightly bent release fork like what happened to jake Quote Link to comment Share on other sites More sharing options...
0 philgor Posted September 10, 2015 Share Posted September 10, 2015 A short shifter will make it worse... Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 11, 2015 Author Share Posted September 11, 2015 Good Morning guys, thanks everyone for the replies. Yesterday I drove the car in the city no problem shifting to second, I even shift from 1st to 2nd at 8000 rpm to see if I could replicate the "crunch feel" it was ok. I stopped the car 1 hour late I was feeling it again, as I said it makes it randomly. Tomorrow I will go to my mechanic and he said he will inspect the car and the last thing he wants to check is the gear box, and if its the syncro rings he can replace it. He also told me it could be the clutch, but my clutch is disangaging properly and not slipping. One question, if its the case that the synchro rings are worn, all B series use the same synchro rings ? any advantage using OEM vs Carbon rings ? Thanks Quote Link to comment Share on other sites More sharing options...
0 Krzys Posted September 11, 2015 Share Posted September 11, 2015 With the EP3 the crunching is the pressure plate failing within the clutch pack, but you get a heavy pedal and a low bite point which you say isn't the case here. All of the B series synchros should be the same size. I have carbon lined ones which make the gear changes feel super smooth! It's up to you if you want to pay the extra for them over standard ones. Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 11, 2015 Author Share Posted September 11, 2015 Ok I will see after the mechanician see whats wrong, a talked with a specliast guy that work with Honda cars only, he said the same thing as Jay, It can be a bent fork. Quote Link to comment Share on other sites More sharing options...
0 Krzys Posted September 11, 2015 Share Posted September 11, 2015 Fingers crossed its nothing major! Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 11, 2015 Author Share Posted September 11, 2015 Well lets see, I dunno if could be a Bent fork, because i think i would feel it with engine off. the thing is I only feel it when the engine is turned ok and driving Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 14, 2015 Author Share Posted September 14, 2015 Good Morning everyone, After driving in the weekend, I found that my gearbox is more smooth when its cold, and after waming up I start feeling everything on the gearbox. My mechianician told me its the clutch, because if it was the gearbox I would feel rough everytime. Quote Link to comment Share on other sites More sharing options...
0 Viltor Posted September 18, 2015 Author Share Posted September 18, 2015 Good Morning everyone, yesterday night I went un der my car too see the gear linkage etc and I noticed that i had a leak beatween the gearbox and the block, with brown oil. is MTF3 brown ? could it be possible that im losing MTF from there and thats why I feel that on the gear/gears ? I also noticed with the engine off (I dont know if thats normal or not) but if I pres the clutch and let it there for few seconds and I try to change gears, most of them block halfway. Thanks Quote Link to comment Share on other sites More sharing options...
Question
Viltor
Hello everyone,
Thanks
Top Posters For This Question
4
7
25
4
Popular Days
Sep 10
12
Sep 9
7
Sep 3
7
Sep 11
5
Grant 4 posts
Krzys 7 posts
Viltor 25 posts
Gel 4 posts
Popular Days
Sep 10 2015
Sep 9 2015
Sep 3 2015
Sep 11 2015
Popular Posts
Krzys
Dude, seriously take it to a garage, this is getting no where....
Grant
Initial suggestion would be an absolute must to replace the fluid. Then go from there
KiNK43
Annoyingly
49 answers to this question
