arf4n1 Posted December 24, 2015 Author Share Posted December 24, 2015 Thanks for the help guys...anyway so far ive done;Heater matrix removed, checked and refittedChecked under scuttle panel, cleaned and sealedResealed around windscreenChecked sunroof and cleaned drainStill the same Quote Link to comment Share on other sites More sharing options...
Krzys Posted December 24, 2015 Share Posted December 24, 2015 Might be a long shot but have you check the sunroof drains? Not sure they'd cause water to come out from there but it might lead you to the cause? Quote Link to comment Share on other sites More sharing options...
Jayhoath83 Posted December 24, 2015 Share Posted December 24, 2015 Have you looked for rust holes on the bulkhead as these cars have been known to rust out on the inner arch and then bulkhead allowing water from the road in could be worth checking Quote Link to comment Share on other sites More sharing options...
Aky-Mb6 Posted January 2, 2016 Share Posted January 2, 2016 Krzys - he said he's checked the drains... on the post above yoursIf it's coming through the heaters and your not loosing coolant is not going to be the heater matrix, it's probably the seal under the scuttle panel letting water drip into the fan. Lift the scuttle panel and check the seal under it. Quote Link to comment Share on other sites More sharing options...
Jayhoath83 Posted January 4, 2016 Share Posted January 4, 2016 Krzys - he said he's checked the drains... on the post above yoursIf it's coming through the heaters and your not loosing coolant is not going to be the heater matrix, it's probably the seal under the scuttle panel letting water drip into the fan. Lift the scuttle panel and check the seal under it. like wise dude hes checked the scuttle too Quote Link to comment Share on other sites More sharing options...
Aky-Mb6 Posted January 5, 2016 Share Posted January 5, 2016 like wise dude hes checked the scuttle tooThat's true mate, but if it's coming through the heaters that's the only place it can be from. The foam seal under the panel is really fragile and if there's a tears it basically drips right into the fan. I'm guessing he sealed around the screen and the top bit when the panels back on. Then again I could be wrong and he's sealed that aswell Quote Link to comment Share on other sites More sharing options...
Jayhoath83 Posted January 5, 2016 Share Posted January 5, 2016 Thats the thing without seeing more pics its anyones guess Quote Link to comment Share on other sites More sharing options...
simpo Posted February 4, 2016 Share Posted February 4, 2016 Do you have a sub and amp? Could be the wire from that going into the car Quote Link to comment Share on other sites More sharing options...
