Jayhoath83 Posted January 5, 2016 Share Posted January 5, 2016 It sound like you have the loom to do a conversion on a d series to b series in an eg ? Quote Link to comment Share on other sites More sharing options...
Sutty1596 Posted January 7, 2016 Author Share Posted January 7, 2016 My loom is obd2b it's a d16w4 aerodeck non vtec and I'm swapping it for a b16a which is obd1 will my loom work or will I have to use the loom that I have bought with engine? Quote Link to comment Share on other sites More sharing options...
Chandler Posted January 7, 2016 Share Posted January 7, 2016 the D16W4 is eco vtec mate Quote Link to comment Share on other sites More sharing options...
Sutty1596 Posted January 7, 2016 Author Share Posted January 7, 2016 Not the w4 then pretty sure it's w# maybe w2 am I right in saying that it would be obd2b as they all changed to that 98 onwards or was that a US thing? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 8, 2016 Share Posted January 8, 2016 First things first.You should have some grey connectors. In your engine bay on the shock tower in front of battery. This is where your 2 part loom separate's. So has the new engine loom got these same connectors??? Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted January 8, 2016 Share Posted January 8, 2016 If you want to use your d series obd2 loom. It will work you may need to swap your injectors over and possibly replace the dizzy plug and extend a few bits. Also add vtec wire all the way back to ecu if non vtec. Hard to say specifically because we don't know exactly what part's you have. Quote Link to comment Share on other sites More sharing options...
Sutty1596 Posted January 8, 2016 Author Share Posted January 8, 2016 Cheers mate I'll have a look today after work gotta sort everything out find out what's what and what's where! So in theory if my new loom has these same connectors I can just use my loom that's already in there just extend a few bits and wire in vtec? Have to try dumb it down for myself it's early and I haven't got a clue aha thanks for help Quote Link to comment Share on other sites More sharing options...
