ep82 Posted April 30, 2010 Share Posted April 30, 2010 Can someone tell me how hard is it to tighten up the alternator belt? And how to tackle this? The sqeeking is driving me nutsis it a job for anyone or best for a garage? Link to comment Share on other sites More sharing options...
simpo Posted May 1, 2010 Share Posted May 1, 2010 very easy to do mate just loosen the bolt get a bar to lever it (be careful thou) tighten bolt. sure the belt dont need replacing? i will try and get some pics of the bolts and that Link to comment Share on other sites More sharing options...
simpo Posted May 1, 2010 Share Posted May 1, 2010 right if you look at where the pulley on the alternator, just to the left is a 12mm bolt (think its 12mm) thats the one you wanna loosen and lever. just make sure when you lever it to hold the pressure when tighten it over wise will be worse Link to comment Share on other sites More sharing options...
ep82 Posted May 1, 2010 Author Share Posted May 1, 2010 Nice one Adam. I will give it a go Link to comment Share on other sites More sharing options...
noodels Posted May 1, 2010 Share Posted May 1, 2010 over- tightning does your bearings in expensive so dont be too keen? Link to comment Share on other sites More sharing options...
simpo Posted May 1, 2010 Share Posted May 1, 2010 no worries hope you sort it Link to comment Share on other sites More sharing options...
jalesi2001 Posted May 1, 2010 Share Posted May 1, 2010 There is a 14mm bolt on the bottom of the alternator as well guys!! Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 2, 2010 Share Posted May 2, 2010 There is a 14mm at the bottom to you need to loosen off that to . Rich. Link to comment Share on other sites More sharing options...
ep82 Posted May 2, 2010 Author Share Posted May 2, 2010 Thanks for the info Link to comment Share on other sites More sharing options...
simpo Posted May 2, 2010 Share Posted May 2, 2010 sorted? Link to comment Share on other sites More sharing options...
