  • 0
skitzma8
Civic d series turbo engine misfire
Today my d series turbo d15z has stating misfiring at low rpm my water expansion bottle has overflowed and slightly leaked on to my air filter and it’s damp, would this be enough to go through my intercooler piping and intercooler and into the engine? To cause a misfire as it’s a long way for water to travel. Help is appreciated thanks
Share this post
Link to post
4 answers to this question
  • 0
it would have needed a fair amount of water to pass through. remove the filter clean and dry it then I'd be removing the spark plugs and checking the leads.. then go from there
Share this post
Link to post
  • 0
Thanks for the reply today on closer inspection the car is not misfiring it’s leaking exhaust gases around the manifold area, could possibly be a blown manifold gasket, a blown t3/t4 turbo flange gasket, or a crack in the manifold I can not see it being anything else it has to be one of these that’s the culprit I’ll have to pull it apart and see what’s happened as I pushed the car to 150+ mph when this happened (private road)
Share this post
Link to post
  • 0
What power is it making
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
Answer this question...
