raft3780 Posted May 7 Share Posted May 7 Hello I have a 1997 MB3 Civic that i want to install better speakers in. Is the front door speaker grill removable? Or do i have to pull the whole door cover for new speaker, and if so how do i do this? with regards Quote Link to comment Share on other sites More sharing options...
0 dr_broon Posted May 7 Share Posted May 7 Yes, the whole door card has to come off as the speaker cover is part of that. Can't remember for sure, but I think that they can be separated once the door card is off if that's what you want to do, but if it's just too change the speaker it's just the door card that needs to come off. I'm sure there's a how to on here somewhere, but there's a screw to loosen the handle/latch, which then has to slide forwards (or back... Not 100% which but it's obvious when you try to do it). Then there's a little plastic clip that keeps a metal rod in the handle.. Careful not to snap the clip. Then there's two other screws in the grab handle on the door card. Once they're out you'll need to pop out some trim clips around the edge of the card, then Bob's your uncle. Quote Link to comment Share on other sites More sharing options...
raft3780
Hello
with regards
1 answer to this question
