slammed b20 deck /gone now/
prezes
Strut bar is fitted! So there it is... First MC2 with a C pillar Bar!!!
If not hard can make photo strut bar at fixing points. I want to do this yourself...
  • Replies 1.1k
Ill get a pic for you mate.
James from DNR fixed the injector leak for me today, I've cleaned the throttle body & IACV yesterday but the code 43 is back again, intermittent hesitation below 2k rpm... I think I will replace the o2 sensor but just wondering which one to buy - the £25 so called universal one, the £55 bosch one or the over £100 ngk etc ones. I know you tend to get what you pay for but just not keen on spending a lot on a part that may be just fine and may end up buying fuel pump etc...
Any advice ?
they are same thing. just NTK branding for lambda. i am replacing mine o2 hopefully over the weekend. i have stutter bang on 2k and im sure this is the cause!
i think o2 mate. i have had issue with mine ever since changed the dizzy. but changing ignition timing makes no difference. so i can only assume my o2 was damaged by all the crtanking and no start. ie fuel in exhaust.
good luck getting it sorted anyway.
