VTI-S Turbo question????
CMSCIVICVTI
Ok mate that's good to know. Seen as I won't be running anywhere near as much power as you were do you think it will be ok to use on my project? I probably will end up getting a properly chipped and mapped ecu but could I use the blue box at least to make it drivable?
  • Replies 41
Yes it will be fine to get the car running right , but like i say its the wiring thats the hard part . you need wire diagrams for the emanage and then the ecu pinout diagram for the mb6 . But if you have that its about an hours work to wire it in , but you are best to see if you have anyone in your area that has the software to map emanage as the last thing you want is a ecu that noone near you can map . Rich.
