CMSCIVICVTI Posted December 2, 2010 Author Share Posted December 2, 2010 Ok mate that's good to know. Seen as I won't be running anywhere near as much power as you were do you think it will be ok to use on my project? I probably will end up getting a properly chipped and mapped ecu but could I use the blue box at least to make it drivable? Link to comment Share on other sites More sharing options...
civicturbo79 Posted December 2, 2010 Share Posted December 2, 2010 Yes it will be fine to get the car running right , but like i say its the wiring thats the hard part . you need wire diagrams for the emanage and then the ecu pinout diagram for the mb6 . But if you have that its about an hours work to wire it in , but you are best to see if you have anyone in your area that has the software to map emanage as the last thing you want is a ecu that noone near you can map . Rich. Link to comment Share on other sites More sharing options...
