Shaddow Posted November 9, 2010 Share Posted November 9, 2010 Hi guys,Iv had a look around but not found the information I am after and was hoping if anyone on here could help.The backlights on some area's of my centre console has gone out and needs to be replaced. How can I get to them to replace, and which bulbs are they so I can order them before I remove the bits.The specific area's I am after is the one side of the heater control dials, the button at the top switching the rear window heater on/off and then to the right of the steering wheel (RHD Cars) the little pannel controlling the headlight level and dash backlit adjuster.Any guides available along with likely time to complete etc..Thanks! Link to comment Share on other sites More sharing options...
Sega Posted November 9, 2010 Share Posted November 9, 2010 Just pop out the relevent parts of the dash, theres a downloadable manual on here that will show you how to do it, pop into your local auto factor and get them to match the bulbs for you. Link to comment Share on other sites More sharing options...
dr_broon Posted November 9, 2010 Share Posted November 9, 2010 Recently found maplins do bulbs for the backlights on switches..check out how to here: viewtopic.php?f=91&t=3842 Link to comment Share on other sites More sharing options...
Shaddow Posted November 9, 2010 Author Share Posted November 9, 2010 Thanks guys, I found that manual you listed dr_broon, but it does not show parts such as the temperature setting dial. Does that also just pull out or does that remove in some other method?Thanks Link to comment Share on other sites More sharing options...
