RS1T Posted February 12, 2011 Share Posted February 12, 2011 Hey guys,Got a slight problem with my 99 civic aerodeck, when I lock the car using the key fob, after about 2 minutes the car alarm always goes off. If I lock it manually with the key then this doesn't happen.Am I doing something stupid or is there a fault with the car? Many thanks Link to comment Share on other sites More sharing options...
james Posted February 12, 2011 Share Posted February 12, 2011 is there a sensor for the bonnet Link to comment Share on other sites More sharing options...
RS1T Posted February 12, 2011 Author Share Posted February 12, 2011 I don't know, but the bonnet is definately closed Link to comment Share on other sites More sharing options...
james Posted February 12, 2011 Share Posted February 12, 2011 yea ok look for a sensor along the beam where the bonnet catch is you will be able to push it down like a button this is for the alarm when activated if the bonnet is opened the alarm is triggered on mine i had the same prob and the wire on this connection had come off and was dangling freely and hitting the body work thous setting the alarm off Link to comment Share on other sites More sharing options...
RS1T Posted February 12, 2011 Author Share Posted February 12, 2011 Ok will try that.Is it possible that a low battery in the key fob will be causing the alarm to go off? Link to comment Share on other sites More sharing options...
james Posted February 12, 2011 Share Posted February 12, 2011 doubt it Link to comment Share on other sites More sharing options...
the mad kiwi Posted February 12, 2011 Share Posted February 12, 2011 my mrs can was doing the same thing after lots of fkn around it was the boot sensor try disconecting each sensor one at a time and see what happens Link to comment Share on other sites More sharing options...
RS1T Posted February 12, 2011 Author Share Posted February 12, 2011 Just changed the battery, it's still doing it :/Will try checking the sensors, but I have no Idea where the sensors are...Can you give me some pointers to find the door, bonnet and boot sensors?Also what should I do when I find the sensors? Unplug each one and then lock it, see if alarm goes off?Many thanks, Alex Link to comment Share on other sites More sharing options...
RS1T Posted February 13, 2011 Author Share Posted February 13, 2011 Here's an update. I found the wire that connects the bonnet sensor to the alarm system unplugged and dangling....I wrapped it in electrical tape so it shouldn't come into contact with the bodywork, but when I locked it again the alarm still goes off Tried looking for the boot sensor, but couldn't find it at all. Door sensors seemed to be working, I tested each one with the interior light on the door setting and it turned on when each one was opened. Link to comment Share on other sites More sharing options...
simpo Posted February 13, 2011 Share Posted February 13, 2011 surly you would wanna connect the boot sensor and not have it dangling Link to comment Share on other sites More sharing options...
