james Posted February 13, 2011 Share Posted February 13, 2011 WAHT your haven a laughthats because you have probly pumped the peddel with the ignition off Link to comment Share on other sites More sharing options...
jonnyricer Posted February 13, 2011 Share Posted February 13, 2011 Have you tried remove plate from gear box casing lock flywheel with a big screw driver and then use a big bar!!I've done it this way before if not I use a3/4 inch air gun! Link to comment Share on other sites More sharing options...
acivic Posted February 13, 2011 Share Posted February 13, 2011 Ive been reading on the crankshaft pulley bolt on the net & its scary because I dont want anyone to do damage to my engine or car, especially as alot of places e.g back street garages dont seem to have a clue. I read you need this toolhttp://cgi.ebay.co.uk/ACCORD-CIVIC-CRAN ... 45f3406173 which holds the crankshaft pulley still in place whilst you remove the crankshaft pulley bolt, & that way bolt comes off easier & no damage. Ive read some people bolting old metal bed frame to the pulley & jamming the metal bed frame to the ground. I read that honda use loctite on the thread-can anyone whos done one before confirm this? is there red or blue loctite on the thread of the bolt? Ive read some people jamming a screwdriver in the flywheel & end up doing more damage by breaking the screwdriver, resulting in bits of the screwdriver remaining I'd really like to know the professional way. I read somewhere honda use a special tool/ equipment thats a 'Z' shape bit which stops the crankshaft pulley from moving, when the bolt is being done. Link to comment Share on other sites More sharing options...
shebabby Posted February 13, 2011 Author Share Posted February 13, 2011 Ive been reading on the crankshaft pulley bolt on the net & its scary because I dont want anyone to do damage to my engine or car, especially as alot of places e.g back street garages dont seem to have a clue. I read you need this toolhttp://cgi.ebay.co.uk/ACCORD-CIVIC-CRAN ... 45f3406173 which holds the crankshaft pulley still in place whilst you remove the crankshaft pulley bolt, & that way bolt comes off easier & no damage. Ive read some people bolting old metal bed frame to the pulley & jamming the metal bed frame to the ground. I read that honda use loctite on the thread-can anyone whos done one before confirm this? is there red or blue loctite on the thread of the bolt? Ive read some people jamming a screwdriver in the flywheel & end up doing more damage by breaking the screwdriver, resulting in bits of the screwdriver remaining I'd really like to know the professional way. I read somewhere honda use a special tool/ equipment thats a 'Z' shape bit which stops the crankshaft pulley from moving, when the bolt is being done.omg i wer guna make one but at that price cheers mate Link to comment Share on other sites More sharing options...
cal Posted February 13, 2011 Share Posted February 13, 2011 take it to a garage buzz the bolt loose with a proper air gun. nip it then drive home Link to comment Share on other sites More sharing options...
acivic Posted February 14, 2011 Share Posted February 14, 2011 I found this useful vid Link to comment Share on other sites More sharing options...
james Posted February 14, 2011 Share Posted February 14, 2011 what you need is axel stand or something the same hight 2/3 long extensionslong braker barpipe to fit over braker bara friendget a big braker bar put a pipe over if, put you socket on the bolt attach extensions rest them on axel stand or similar attach braker bar/pipe have your friend sit in the car put it in fifth gear press the brake then loosen the bolt, it will take some force getting it loose dont worry its torques to 170nm + rust + how long it has been on therere torque the bolt to the manufacturers recommendationsdude this is the the one i cant see it not working likethe brake can stop a car doing 140 mph it will hold the engine from turning Link to comment Share on other sites More sharing options...
shebabby Posted February 14, 2011 Author Share Posted February 14, 2011 i know mate iv done that a few times before .i tried but the bolt wer that tight i didnt want to brake owt !!id rather shock it off with a gun . Link to comment Share on other sites More sharing options...
shebabby Posted February 14, 2011 Author Share Posted February 14, 2011 take it to a garage buzz the bolt loose with a proper air gun. nip it then drive homethink i will then if the bolt brakes Link to comment Share on other sites More sharing options...
acivic Posted February 14, 2011 Share Posted February 14, 2011 Even though I would definitely use correct tool/s. Check out this dude 'frylockthefryman' he attached a chain on the crank pulley to the front tow hole credit goes to 'frylockthefryman' his vids have alot of info Link to comment Share on other sites More sharing options...
