johngreen537 Posted February 14, 2011 Share Posted February 14, 2011 Last time I used one of those cheapo extendable wheel braces!Socket is 19mm which just hapens to be the same as a Honda wheel nut, so itworked a treat.Leave it in 5th, if you can get a bar long enough to protrude to the front of the car (mine was 'just' too short, so I took the bumper off!) then stand on it an bounce I've stopped using WD40 now for 'rusty' bolts, takes too long!I bought some freezing stuff, which basically freezes the metal to -40 degrees, then as it warms back up 5 mins later, the metal expands, and cracks it's own rust I buy it from motor factors, about 6 quid a can, which does 2 bolts or so, but well worth it for the hastle it saves! Link to comment Share on other sites More sharing options...
bepilot Posted February 14, 2011 Share Posted February 14, 2011 Have you tried remove plate from gear box casing lock flywheel with a big screw driver and then use a big bar!!I've done it this way before if not I use a3/4 inch air gun!I've done this method with my car and it worked... we didn't remove the plate, there is a hole to put the screwdriver in (perhaps yours was a tickle too large). Link to comment Share on other sites More sharing options...
shebabby Posted February 15, 2011 Author Share Posted February 15, 2011 some bloody good ideas on here maybe if i use them all at once it will go havnt had time so far needs doin asap tho !!!! Link to comment Share on other sites More sharing options...
Fathead87 Posted February 15, 2011 Share Posted February 15, 2011 I had the same prob. So I bought the crank holding tool.a 4ft breaker bar a super size jack handle n 2 mates, we all hung off of it. After the extension bar twisted no a lot of swearing it loosened. Yayyy Link to comment Share on other sites More sharing options...
jalesi2001 Posted February 17, 2011 Share Posted February 17, 2011 Glad you got it sorted dude!! Just to confirm, there is NO lock-tight on the tread, they are just very very tight!!I use a 3/4 inch airgun to get them off, and buzz them up with a 1/2 inch airgun. You need a decent compressor too!! I call my 3/4 inch gun 'big burtha', she is a beast and weigh's a ton!! Never been beaten yet though!! Link to comment Share on other sites More sharing options...
shebabby Posted February 18, 2011 Author Share Posted February 18, 2011 Glad you got it sorted dude!! Just to confirm, there is NO lock-tight on the tread, they are just very very tight!!I use a 3/4 inch airgun to get them off, and buzz them up with a 1/2 inch airgun. You need a decent compressor too!! I call my 3/4 inch gun 'big burtha', she is a beast and weigh's a ton!! Never been beaten yet though!! but wot would i call ar lass then Link to comment Share on other sites More sharing options...
johngreen537 Posted February 18, 2011 Share Posted February 18, 2011 Windy Guns FTW Link to comment Share on other sites More sharing options...
jonnyricer Posted February 18, 2011 Share Posted February 18, 2011 we got the 3/4 inch gun called big burtha maybe they re related?? Link to comment Share on other sites More sharing options...
jalesi2001 Posted February 25, 2011 Share Posted February 25, 2011 PMSL!! Yeah could be mate!! Link to comment Share on other sites More sharing options...
shebabby Posted March 18, 2011 Author Share Posted March 18, 2011 after alot ov trying i finaly got my crank pully bolt out but not everything went to plan ! after fabricating my own tool to hold the pully whilst i loosened the bolt my hopes wer high the tool was a tight fit so wen i took the pully off i left the tool inserted in the pully !bad idea as wen i took it off it wer slightly warm and as it cooled it fused the tool to the pullyso instead ov heating it up a little i decided to tap them apart useing a socket and a hammer wen i got them apart i turned the pully over to check its condition i noticed that i had cracked it just my look so now iv got to buy one . iv been looking on ebay and found this http://srx.uk.ebayrtm.com/clk?RtmClk&u= ... 78π=5197 was woundering if anyone has bought one ov these if so would like to hear !thanks !!! Link to comment Share on other sites More sharing options...
