mb6vti Posted August 28, 2009 Share Posted August 28, 2009 read my response the answer is in it why I did not use the koni springs - I suspect your someone who skim reads a post Link to comment Share on other sites More sharing options...
tontvti Posted August 28, 2009 Author Share Posted August 28, 2009 I read it The koni springs that came part of the kit lowered more than 35mm - I spoke to Paul at Koni who said 40mm. But when we fitted them to my mates mb6 the front and rear went down approx 50mm.Is that too low??? Stock ground clearance is pretty epic Link to comment Share on other sites More sharing options...
megamitzmb6 Posted September 4, 2009 Share Posted September 4, 2009 kyb agx shocks and eibach springsshock are 4 way adjustable i have them on hard with 3 kids and a fat bird and no complaints lolvery good ride, like the wife's best matenot height adjustable and maybe the back sits a tad higher but overallsuperb, handles very well Link to comment Share on other sites More sharing options...
FlunkyVTEC Posted September 4, 2009 Share Posted September 4, 2009 I read it The koni springs that came part of the kit lowered more than 35mm - I spoke to Paul at Koni who said 40mm. But when we fitted them to my mates mb6 the front and rear went down approx 50mm.Is that too low??? Stock ground clearance is pretty epicI have been playing around with the height adjustment of my MB6 and have had it at approx. 4 to 4,5 cm lower than standard (one finger between top of tire and arch in front). What I found was that it was manageable when driving around alone (if you take speed bumps patiently) but as soon as I had some passengers it would hit. First the tow hooks in front would hit the speed bump, even at snale pace, and if you were unlucky the bottom would scrape until the rears were over the bump. When going off the bump sometimes even the rear tow hook would hit it. If I would put my suspension to rock solid it might help a bit. I have now raised her so she's approximately 3,5 cm. lower and thusfar it seems to be perfect, even with 3 passengers of which 2 could be described as obese, as long as you take speed bumps slowly.This is how she's currently sitting: Link to comment Share on other sites More sharing options...
FREAKBOY Posted September 14, 2009 Share Posted September 14, 2009 I used P.I. matched springs on my Aerodeck (40mm drop) and they are spot on. I can't fault them at all. Very good ride height, not too stiff at all. When loaded they don't sag. They transformed the handling for normal fast road use without compromising the Honda comfort. Stock dampers are retained. Link to comment Share on other sites More sharing options...
Guest kev21 Posted September 22, 2009 Share Posted September 22, 2009 what site do you get avo coilovers for 550 from Link to comment Share on other sites More sharing options...
gary87 Posted September 23, 2009 Share Posted September 23, 2009 Has anybody tried the Koni Street kit? I am just looking a slightly harder shock than standard because the standard ones are p**s. I want a bit more handling without having to put coilovers in.ThanksGary Link to comment Share on other sites More sharing options...
tontvti Posted September 23, 2009 Author Share Posted September 23, 2009 what site do you get avo coilovers for 550 fromI spent a full week searching the webto get those lowest prices I've got three laptops, it'll be in the favourites on one of them.Reviews of the budget koni street kits and PI kits would be appreciated Link to comment Share on other sites More sharing options...
seanmb6vti Posted September 25, 2009 Share Posted September 25, 2009 http://www.motorsportworld.co.uk/frame- ... ranges.asp Link to comment Share on other sites More sharing options...
tontvti Posted December 1, 2009 Author Share Posted December 1, 2009 So most recommended are;Koni sport shocks/eibach springs £400 + £200D2 RS coilovers £550BC coilovers £550KW's £££We must be able to get good suspension < £300, all we need is a progressive spring and a decent damper.Anyone tried Jamex Xtreme coilovers £300, Jamex shocks/springs, or the ebay £200 coilovers Link to comment Share on other sites More sharing options...
