knight Posted June 25, 2011 Share Posted June 25, 2011 I'dbe looking at IAB's mate.Check they open. When the engine is off, they are wide open, when the engine runs, the solenoid closes and shuts odd the butterflies till 6k.When you start the engine, you should see the vacuum plunger moving....If it's not moving, then there is an issue. I'd say you are likely to have IAB issue, rather than fuelling.X2 i had Iab problem and i thought i could hear the 6000 sound change but it felt like there was no go in it wasn't till the dyno showed i was 25bhp down and found the iab solenoid was f***ked! got a new one and all is good! pulls like a train at 6000+ now and the sound is very loud on crossover Link to comment Share on other sites More sharing options...
aarondevine Posted June 25, 2011 Author Share Posted June 25, 2011 aye, when you switch the car on the plunger moves and when i got a friend to rev the car i could see the plunger move at 6000! my car has a decat so should rule that out! Link to comment Share on other sites More sharing options...
johngreen537 Posted June 25, 2011 Share Posted June 25, 2011 O2 sensor replacement then mate.You getting any fault codes from the 2 prong reader method? Link to comment Share on other sites More sharing options...
aarondevine Posted June 25, 2011 Author Share Posted June 25, 2011 aye was thinkin down that line again myself, was thinking she might not be adjusting the fuel trims properly! naw no fault codes?? Link to comment Share on other sites More sharing options...
