noodels Posted August 16, 2011 Share Posted August 16, 2011 jake used silicon, tiger is rubber type poly bushing comes in stiffnessthis is the advantage ie someone has done the formular for you.this is upto the person who does the mod, .to hard=vibration ect/to soft =axel tramp.WOULD NOT RECOMEND RTA BUSHES DONE THIS WAY AS TOE IN/OUT IS DIALED IN UNDER BRAKING FOR STABILITY Link to comment Share on other sites More sharing options...
james Posted August 17, 2011 Author Share Posted August 17, 2011 eom it is for the lcahhhhmmm what will the advantages be over oem on the torque mount, to poly or tiger seal Link to comment Share on other sites More sharing options...
noodels Posted August 17, 2011 Share Posted August 17, 2011 The oem bushings are a crap design four fingers holding the engine from moving ...wtf can i get a poly one or what to help this Link to comment Share on other sites More sharing options...
james Posted August 17, 2011 Author Share Posted August 17, 2011 would it matter if i put the seal on the old/broken mount or would i be better getting a new mount and filling that Link to comment Share on other sites More sharing options...
noodels Posted August 17, 2011 Share Posted August 17, 2011 new one mate or s/h do both fronts so even pressure,but would go for energy inserts to be honest,they do both fronts and rear firewall one also, and once installed will last and last as not much movement http://www.ebay.co.uk/itm/Energy-Suspen ... 3cbaf4b4db Link to comment Share on other sites More sharing options...
james Posted August 17, 2011 Author Share Posted August 17, 2011 woop woop thanks andrew that a cheap price Link to comment Share on other sites More sharing options...
civic jay Posted August 18, 2011 Share Posted August 18, 2011 cheers for the link noodels, ialso need to get the torque mount sorted.has anyone got these fitted? do they make much difference? Link to comment Share on other sites More sharing options...
noodels Posted August 18, 2011 Share Posted August 18, 2011 yes mate front only atm very good upgrade and easy to fit rear looks Bad to fit :0(hence not done yet be easy- er with a ramp!!belive it or not this is part of the suspensionof a vehicle one has to tune all the componants when performance tweaking suspension wise,all main mounts ect.. Link to comment Share on other sites More sharing options...
DeLaSoul Posted August 19, 2011 Share Posted August 19, 2011 cheers for the link noodels, ialso need to get the torque mount sorted.has anyone got these fitted? do they make much difference?I've just done the side mounts with the Energy suspension bushes, to me the car doesn't feel any different at idle/low speed, but you do notice more vibration/harshness on a more spirited drive. I have to do the rear mount this weekend so I can let you know about the total package then. Link to comment Share on other sites More sharing options...
james Posted August 19, 2011 Author Share Posted August 19, 2011 nice one dave looking forward to the report Link to comment Share on other sites More sharing options...
