leejt1979 Posted September 6, 2011 Author Share Posted September 6, 2011 surely if the coil was faulty it would be a continuous miss??? i have reset the ecu and have the same problem with no faults logged!! arrgghhhhh..... frustration!!! just want her to run smooth Link to comment Share on other sites More sharing options...
KiNK43 Posted September 6, 2011 Share Posted September 6, 2011 lambda i think. i had a ignition coil go and it was just instant! no mis or anything, just car died. and besides miss would surely be higher rpm if coil.from what i was told thats just what happens to these honda coils. no messing about just die all of a sudden1lambda wouldnt necessarily throw code. might just be within acceptable parameters but bad enough to cause an issue.also lambda isnt used on full throttle so if it pulls properly at low low rpm full throttle... then surely gotta be lambda.but i am no expert, just trying to use the little bit of common sense i have left.good luck. Link to comment Share on other sites More sharing options...
leejt1979 Posted September 18, 2011 Author Share Posted September 18, 2011 thanks for all the help... car is running perfectly now ... it was indeed the lambda sensor!! Runs so much smoooother.. very happy boy once again!! Link to comment Share on other sites More sharing options...
KiNK43 Posted September 18, 2011 Share Posted September 18, 2011 yay happy ending. glad you got sorted.didi you use jonda lambda or cheapy one? Link to comment Share on other sites More sharing options...
leejt1979 Posted September 18, 2011 Author Share Posted September 18, 2011 NTK... OE quality at a fraction of the price.. Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted September 18, 2011 Share Posted September 18, 2011 Glad you got it fixed.When I replaced mine I didn't use an OEM one and mines been fine. Link to comment Share on other sites More sharing options...
