james Posted November 11, 2011 Share Posted November 11, 2011 the reason it wont come on isthe rad cap is off which means no pressure in the cooling system which means coolant is not hot enough to trigger the fan Link to comment Share on other sites More sharing options...
mb6loon Posted November 12, 2011 Author Share Posted November 12, 2011 ok got the heater to come rad fan to come on 3-4 times yet still seeing little air bubbles been out at the car for the past hr wish i had never changed the thermostat now lol Link to comment Share on other sites More sharing options...
james Posted November 12, 2011 Share Posted November 12, 2011 spueeze the bottom hoseis it hot? is there bubbles when you squeeze it Link to comment Share on other sites More sharing options...
mb6loon Posted November 12, 2011 Author Share Posted November 12, 2011 bottom hose is roasting hot and yes there is some bubbles i took it for a thrash earlyer and it didnt seem to use any think i got it fixed but not 100% surebtw james thanks for your help Link to comment Share on other sites More sharing options...
weetec Posted November 12, 2011 Share Posted November 12, 2011 did you seal the thermostat housing with some hondabond or something....mine was leaking after replacing the stat from the housing... had no choice but to apply honda bond. Link to comment Share on other sites More sharing options...
mb6loon Posted November 12, 2011 Author Share Posted November 12, 2011 no didnt do it with hondabond but it don't seem to be leaking its dry put felt around the house thanks for the info though Link to comment Share on other sites More sharing options...
james Posted November 13, 2011 Share Posted November 13, 2011 well if you have anymore worries just type!i know whats its like to get a helping hand when things are not going your way.... a extra push is all it takes Link to comment Share on other sites More sharing options...
mb6loon Posted November 13, 2011 Author Share Posted November 13, 2011 well just an update its bled right just took a dammed long time think i will have to do it again as theres only about 2 ltrs of antifreeze in and the rests water maybe mixed with another 1lr of antifreeze with water i know the water in the rads blueish in colour, had that car out for a few hrs last night and kept checking the levels and it all seems fine now, thanks for the help james Link to comment Share on other sites More sharing options...
KiNK43 Posted November 13, 2011 Share Posted November 13, 2011 i got a tip off civicturbo79, as there is no bleed nipple on these. when system is empty take rad hoses off and boil the water poor that into hoses and let sit for few mins to open stat. then when you fill up the coolant can pass through making bleeding the system much much easier Link to comment Share on other sites More sharing options...
mb6loon Posted November 14, 2011 Author Share Posted November 14, 2011 thanks for that tip will rember that when i come to changing it again as i think theres only 3 litrs of antifreeze in the system Link to comment Share on other sites More sharing options...
