Rev-limit b18c4
kenny_tmt
  • Replies 22
Top Posters In This Topic
  • 3 weeks later...
So what is the Oem rev limit ? Because with the hondata now it is set at 8400..
viewtopic.php?f=69&t=8799
Max power at 8095rpm, rev limiter @ 8395rpm, that was standard with a k & n panel filter, see printout
8-)
you gained almost 10bhp with a k& filter??! thats immense! :twisted:
The standard rev counters are aways out to the rpm of the ecu , standard rev limit is 8100 rpm but the rev counters always show more .
If you get a socketed odb1 ecu and then map the car on chrome you can up the rev limit , add launch control and have a shift light , but to need a chip burner and ostrich so you can live map the car and them burn a chip at the end of the map.
Rich.
