kenny_tmt Posted April 19, 2012 Share Posted April 19, 2012 What is the rev limit of a OEM b18c4 ? Also how high can you raise the rev limit without changing the springs ? Grtz Quote Link to comment Share on other sites More sharing options...
noodels Posted April 19, 2012 Share Posted April 19, 2012 dont forget they are not new you have in,so would leave as is to be safe.. = Quote Link to comment Share on other sites More sharing options...
kenny_tmt Posted April 19, 2012 Author Share Posted April 19, 2012 So what is the Oem rev limit ? Because with the hondata now it is set at 8400.. Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted April 19, 2012 Share Posted April 19, 2012 The standard rev limit is 8175 rpm i think . you can rev it to 8400 rpm not a problem but where is peak power . if its 8000 rpm you are just reving it for no reason . Rich. Quote Link to comment Share on other sites More sharing options...
noodels Posted April 19, 2012 Share Posted April 19, 2012 found this>> so as Rich says 8400 is ok http://scht.us/showthread.php?3764-Hond ... d-tranny-s Quote Link to comment Share on other sites More sharing options...
farmerjoe Posted May 6, 2012 Share Posted May 6, 2012 kenny_tmt said: So what is the Oem rev limit ? Because with the hondata now it is set at 8400..viewtopic.php?f=69&t=8799Max power at 8095rpm, rev limiter @ 8395rpm, that was standard with a k & n panel filter, see printout Quote Link to comment Share on other sites More sharing options...
kern Posted May 8, 2012 Share Posted May 8, 2012 farmerjoe said: kenny_tmt said: So what is the Oem rev limit ? Because with the hondata now it is set at 8400..viewtopic.php?f=69&t=8799Max power at 8095rpm, rev limiter @ 8395rpm, that was standard with a k & n panel filter, see printout you gained almost 10bhp with a k& filter??! thats immense! Quote Link to comment Share on other sites More sharing options...
ryan.. Posted May 8, 2012 Share Posted May 8, 2012 the limiter is about 8400 anyway so it will be fine Quote Link to comment Share on other sites More sharing options...
crazycustomz Posted May 9, 2012 Share Posted May 9, 2012 does this give you launch control or vtec control also? Quote Link to comment Share on other sites More sharing options...
civicturbo79 Posted May 9, 2012 Share Posted May 9, 2012 The standard rev counters are aways out to the rpm of the ecu , standard rev limit is 8100 rpm but the rev counters always show more . If you get a socketed odb1 ecu and then map the car on chrome you can up the rev limit , add launch control and have a shift light , but to need a chip burner and ostrich so you can live map the car and them burn a chip at the end of the map.Rich. Quote Link to comment Share on other sites More sharing options...
