simpo Posted May 5, 2012 Share Posted May 5, 2012 Been looking at getting some new discs at the description says thisFront Discs Specification:Vented - Studs 4Disc diameter 282.0mmDisc thickness 23.0mmOverall height 47.1mmCentre diameter 64.2mmMinimum thickness 21.0mmCan someone confirm this is right for the mb6 Quote Link to comment Share on other sites More sharing options...
noodels Posted May 6, 2012 Share Posted May 6, 2012 114.3 4 stud Quote Link to comment Share on other sites More sharing options...
simpo Posted May 6, 2012 Author Share Posted May 6, 2012 Should be both just wanna know if these were right? Quote Link to comment Share on other sites More sharing options...
EmZvr Posted May 6, 2012 Share Posted May 6, 2012 That's the info for EBC Discs for MB6 which I'm sure are correct:Solid or Vented: VNo of Holes/Bolts: 4Diameter (mm): 282Height (mm): 48Thickness New/Min (mm): 24 -- 21There is difference in height I don't know if it matters. Quote Link to comment Share on other sites More sharing options...
knight Posted May 6, 2012 Share Posted May 6, 2012 My m-tec disks spec,,,, >>>>>>>>>>> http://www.mtecbrakes.co.uk/index.php?m ... mit=Search <<< Quote Link to comment Share on other sites More sharing options...
noodels Posted May 6, 2012 Share Posted May 6, 2012 £ each Quote Link to comment Share on other sites More sharing options...
leejt1979 Posted May 6, 2012 Share Posted May 6, 2012 Just go for OE spec discs with Uprated pads.. LOADS cheaper and very same results Quote Link to comment Share on other sites More sharing options...
