MBK89 Posted May 12, 2012 Share Posted May 12, 2012 Ok so heres the deal, I left the car in the workshop overnight as i borrowed the firms van, when i opened up this morning i went to turn the key and she wouldnt start. Turning and turning but nothing,occasionly shell flutter and all sorts then get going on a normal idle.I can then raise the revs slowly as high as i want and give it nuts at the top end but as soon as i plunge my foot on idle she coughs, splutters cuts out and makes a loud 'croak' from the intake.Things i have checked so far.Seperated exhaust before CAT - wont startRemoved intake and blitzed the throttle body - no different.Over 200PSI in each cylinder on a compression test.All leads sparking and new plugs fitted. Seemed to correct it for a while but then back to square one.Disconnected battery for 10 mins - nothing.Anyone got any ideas. I am a mechanic myself but this just baffles me, maybe some b18 geeks are out there to save me ??RegardsMilky Quote Link to comment Share on other sites More sharing options...
crazycustomz Posted May 12, 2012 Share Posted May 12, 2012 im sure i posted on this but dont know where it went.you could be running too rich,any smoke out the back on start up.try changing your fuel pressure regulator Quote Link to comment Share on other sites More sharing options...
simpo Posted May 13, 2012 Share Posted May 13, 2012 Any fault codes ? It could be dizzy on the way out? Quote Link to comment Share on other sites More sharing options...
MBK89 Posted May 13, 2012 Author Share Posted May 13, 2012 No codes.. took dizzy off all seems ok, cleaned up contacts all round Quote Link to comment Share on other sites More sharing options...
simpo Posted May 13, 2012 Share Posted May 13, 2012 Normally the firing pack inside which messes up Quote Link to comment Share on other sites More sharing options...
crazycustomz Posted May 13, 2012 Share Posted May 13, 2012 dizzy is a common one for these hondas Quote Link to comment Share on other sites More sharing options...
MBK89 Posted May 13, 2012 Author Share Posted May 13, 2012 Anything i can do to check/fix or is just a case of buying a new one? Quote Link to comment Share on other sites More sharing options...
simpo Posted May 13, 2012 Share Posted May 13, 2012 No don't think so unless you got a mate with a mb6 you can borrow a dizzy Quote Link to comment Share on other sites More sharing options...
crazycustomz Posted May 13, 2012 Share Posted May 13, 2012 shame your so far away,i would have happily let you try mine Quote Link to comment Share on other sites More sharing options...
crazycustomz Posted May 13, 2012 Share Posted May 13, 2012 the dc2 integra type r should have the same dizzy aswell if you know anyone that has one of those Quote Link to comment Share on other sites More sharing options...
