simpo Posted June 14, 2012 Share Posted June 14, 2012 How much was a new one? Do you have to get it from Honda? Quote Link to comment Share on other sites More sharing options...
col Posted June 14, 2012 Share Posted June 14, 2012 they're about £250 from honda, try finding someone who's breaking one, ebay etc... Quote Link to comment Share on other sites More sharing options...
shebabby Posted June 15, 2012 Author Share Posted June 15, 2012 they're about £250 from honda, try finding someone who's breaking one, ebay etc...x2 luckilly i had one when i bought the doner deck i recon they will all fit from other civics (5th gen) as long as they have the horn and air bag ? Quote Link to comment Share on other sites More sharing options...
93 Accord Posted April 23, 2014 Share Posted April 23, 2014 Ill bump this as its relevant to my question. So this is related to my M Civic. I have changed my indicator stalk and i stupidly connected the battery while the airbag was out the car. When i put the airbag back in (battery off of course) the SRS light not suprisingly is now on. Can i clarifly the reset procedure from someone please? Quote Link to comment Share on other sites More sharing options...
Krzys Posted April 24, 2014 Share Posted April 24, 2014 Ill bump this as its relevant to my question. So this is related to my M Civic. I have changed my indicator stalk and i stupidly connected the battery while the airbag was out the car. When i put the airbag back in (battery off of course) the SRS light not suprisingly is now on. Can i clarifly the reset procedure from someone please? http://civic5.com/forum/index.php?/topic/129-how-to-reset-srs-light-if-doesnt-go-out-like-it-should/ Here's a guide on resetting the SRS lightOk, why bother to reset the light if it's on?If the light is on its a MOT failure and might cause your SRS system to malfunction,should you get involved in an traffic incident. I found this on the net.Tools Required : A piece of electrical wire and about 15 minutes of time.Step 1 > Locate the SRS connector . It is located in the fuse box behind the driver's flappy storage area. You can simply wiggle the flappy storage bit out without difficulty. And look at the right hand corner of the fuse box and you will see the bright yellow wire and the SRS connector. It should look like this ..[attachment=0]loc2.jpg[/attachment]Step 2> Now press the tab and unplug the SRS connector.Step 3> Now the wire needs to be connected to the SRS connector .Step 4> Now with the wire connected, turn the ignition on (||) but do not start the car. The SRS indicator light should come on and go out in about 8 seconds. Now quickly disconnect the wire. When you disconnect the wire the SRS light should come back on again. Now ! quickly reconnect the wire and the SRS light will go out .Now disconnect the wire and leave it disconnected.If you done it properly the SRS light will flash twice indicating the SRS indicator light has been reset.Step 5> Wait for maybe a minute and then turn the ignition on and start the car as usual and the SRS light should come on and go out like it should do ..And thats it Hope this helps! 1 Quote Link to comment Share on other sites More sharing options...
93 Accord Posted April 24, 2014 Share Posted April 24, 2014 Legend! This site is great 2 Quote Link to comment Share on other sites More sharing options...
Krzys Posted April 25, 2014 Share Posted April 25, 2014 No worries, glad I could help! Quote Link to comment Share on other sites More sharing options...
93 Accord Posted April 30, 2014 Share Posted April 30, 2014 so i did this today, light goes off, when i jumped the connector then i disconect and recconect it goes out then couple seconds later comes on, but stays on. It does not then turn off after 8 seconds as usual after would. What does this mean is wrong? Quote Link to comment Share on other sites More sharing options...
93 Accord Posted May 4, 2014 Share Posted May 4, 2014 Problem sorted, Disconnected the airbag, and then reconnected it, then went through the process again and it works. All good! 3 Quote Link to comment Share on other sites More sharing options...
Krzys Posted May 4, 2014 Share Posted May 4, 2014 Glad you got it sorted mate! Quote Link to comment Share on other sites More sharing options...
