EmZvr Posted May 31, 2012 Share Posted May 31, 2012 I don't like the feeling of the steering rack and this will help. Has somebody done it ? There is a guide here howto remove it and connect a breather system which helps steering when parking but seems hard to do - http://www.civicforums.com/forums/115-e ... ering.htmlSo what do you think ? Quote Link to comment Share on other sites More sharing options...
james Posted May 31, 2012 Share Posted May 31, 2012 i have no power steering (belt removed) and i would =nt advise you do it unless you are strong Quote Link to comment Share on other sites More sharing options...
fyfie5 Posted May 31, 2012 Share Posted May 31, 2012 i have no power steering (belt removed) and i would =nt advise you do it unless you are stronghow much difference does it actually make? as ive never driven a car without it. Quote Link to comment Share on other sites More sharing options...
EmZvr Posted May 31, 2012 Author Share Posted May 31, 2012 X2 I have never driven a car without PS and I'm definitely not in the strong category May be I should remove the belt to see what is like, is it east to remove/reinstall ?Also it will be nice if someone got info on this breather system it is said that makes the steering easier and it is close to having PS. Quote Link to comment Share on other sites More sharing options...
james Posted May 31, 2012 Share Posted May 31, 2012 Eassy to remove belt four bolts at max I wouldn't have removed it only I burst the resoiverIf your not strong you will not be able to steer at skw speeds simply put Quote Link to comment Share on other sites More sharing options...
wezza9 Posted May 31, 2012 Share Posted May 31, 2012 i have driven cars with out PS ( showing my age i guess ) you do get more feel the best PS i ever had was on my 405 Mi16 perfect weight and feel i have a 309gti with a PS rack on it i was told too remove the fluid if i am using it with out the PS the only reason i did is the rack leaked and was a bloody big job too change after having just fitted the Mi16 in so drained and used it that way but if i ever get it back on track then its back on ( not sure if this is true for honda's but i was told for the pug the PS racks are quicker racks ) Quote Link to comment Share on other sites More sharing options...
KiNK43 Posted May 31, 2012 Share Posted May 31, 2012 I'm pretty sure the rack will become damaged eventually if using it as unassisted.And Blimey yes need to be strong. One of previous cars had no power steering with 215/40/17s.Arms like Popeye after a 3 pointer of parallel park. Quote Link to comment Share on other sites More sharing options...
wezza9 Posted May 31, 2012 Share Posted May 31, 2012 oh yer thats true hard work i had a mate who had a had a small steering wheel and sticky tyres on a car with no PS he just got a sweat on just backing his car out of his drive it was also his every dau car and it does shorten the life of the rack too from what i heard Quote Link to comment Share on other sites More sharing options...
EmZvr Posted June 1, 2012 Author Share Posted June 1, 2012 I see, so this won't work. It seemed like a good idea Quote Link to comment Share on other sites More sharing options...
weetec Posted June 1, 2012 Share Posted June 1, 2012 my old C reg Mk2 gold was a nightmare to steer. people would look at me getting in to tight spots as i wrestled with the steering wheel. however i did get a sense of satisfaction when parked. i suppose that kinda explain's the arthiritis. i would not recommend it. Quote Link to comment Share on other sites More sharing options...
