Dexter Posted July 13, 2012 Share Posted July 13, 2012 I failed my MOT a few days ago for a couple of reasons, one of which was that my brake lights are on all the time. Hadn't noticed it before, strange. Any ideas? My guess is a faulty brake light switch so maybe i'll start with replacing that but other suggestions are welcome. The switch is somewhere above the brake pedal, right?Right before the MOT i drove around the block for almost 15 minutes doing pretty hard braking to remove the rust that had covered my rear discs because the car had sat practically immobile for 2 months, so maybe that triggered the problem? Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 13, 2012 Share Posted July 13, 2012 My guess would be the switch too! Again, I'm not 100% sure but also would guess the switch is in the lower dash near the pedal Quote Link to comment Share on other sites More sharing options...
Dexter Posted July 25, 2012 Author Share Posted July 25, 2012 Okay i replaced the switch but it didn't help. To be more specific, when the lights are turned on, the brake lights are on all the time. If lights are switched off, the brake lights only lit up when the pedal is depressed. Any ideas what to try next? Quote Link to comment Share on other sites More sharing options...
Krzys Posted July 25, 2012 Share Posted July 25, 2012 Could be an earth? Check the looms in the tail lights for any burnt out cables?Sounds messy though! Quote Link to comment Share on other sites More sharing options...
Dexter Posted July 25, 2012 Author Share Posted July 25, 2012 Thanks Krzys. Checked the tail lights, all cables looked ok. Removed also the brake light bulbs and checked the bulbholders, looked normal. Removed high mounted brake light and checked it, looked fine. Quote Link to comment Share on other sites More sharing options...
Dexter Posted July 27, 2012 Author Share Posted July 27, 2012 Okay... so the thing is that yours truly had some wrong bulbs in. But strangest this is that it's been many months since i replaced the old ones, and no-one before the MOT ever mentioned or noticed that my brake lights are on all the time? But main thing is that the problem got solved, even though i can't remember when was the last time felt so facepalmed. Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted July 27, 2012 Share Posted July 27, 2012 Oops, at least it's sorted. Quote Link to comment Share on other sites More sharing options...
Krzys Posted August 1, 2012 Share Posted August 1, 2012 How wrong were the bulbs? Quote Link to comment Share on other sites More sharing options...
