burbleboy Posted July 25, 2012 Share Posted July 25, 2012 Hi folks!I recently changes front struts / springs to MGZS stuff but my mate must have damaged a abs sensor. Wires look great, no damage, fuse ok.I have used the search facility and need a wee bit of info and found this on another post;"If you haven't checked the ABS code yet, bridge the two-pin connector on pins 3 & 5 of the 5-pin connector in the passenger footwell, then turn the ignition key to ON (i.e. just before the 'start' position. The sensors are easy to replace; an hourish."Questions;How do i read fault code on ecu as the above description is a tad vague!?I have fitted a p28 ecu so would that be a different way of reading it?Thanks in advance!Alastair Quote Link to comment Share on other sites More sharing options...
burbleboy Posted July 26, 2012 Author Share Posted July 26, 2012 Hi!I just found brilliant thread and followed instruction; viewtopic.php?f=60&t=34Fault code list;viewtopic.php?f=90&t=4268&p=37703&hilit=list+of+fault+codes#p37703However, ive got one flash about a second long followed by 3 blinks. This is repeated constantly.Anyone got any ideas what fault code relates one pause and 3 blinks? I tried with the fault codes above but nothing is relative to 3 blinks!Cheers Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted July 26, 2012 Share Posted July 26, 2012 1 long and 3 short will be 13 (atmos sensor). each long flash = 10. Quote Link to comment Share on other sites More sharing options...
simpo Posted July 26, 2012 Share Posted July 26, 2012 Code 13 front left sensor Quote Link to comment Share on other sites More sharing options...
simpo Posted July 26, 2012 Share Posted July 26, 2012 13 - wheel sensor (open/short to body ground/short to power) FL Quote Link to comment Share on other sites More sharing options...
NIKH25 Posted July 26, 2012 Share Posted July 26, 2012 didn't read far enough down the list. Quote Link to comment Share on other sites More sharing options...
burbleboy Posted July 26, 2012 Author Share Posted July 26, 2012 Guys, thanks you very much!I did my best to try and do it myself but just couldnt understand how to work codes out! Quote Link to comment Share on other sites More sharing options...
WilkesyMB6 Posted July 26, 2012 Share Posted July 26, 2012 Thats the same sensor as what i need, i have ordered one from a car thats breaking so waiting for it to arrive. Quote Link to comment Share on other sites More sharing options...
burbleboy Posted July 27, 2012 Author Share Posted July 27, 2012 Thats the same sensor as what i need, i have ordered one from a car thats breaking so waiting for it to arrive.Fleabay wanted £30 all in posted from lithuania. I took your advice and emailed 4 breakers on ebay and got for £20 posted and chose the seller with best feedback!Result! Quote Link to comment Share on other sites More sharing options...
