noodels Posted April 7, 2012 Share Posted April 7, 2012 wouldnt be RTAs then as not reasponsable for lateral movement,be the rest of your bushes are s**gged out as ITRs are even softer RTAs and is said to handle very well Link to comment Share on other sites More sharing options...
KiNK43 Posted April 7, 2012 Author Share Posted April 7, 2012 It's definately rta bushes causing my issues. I've swung off the trailing arms with a pry bar and all the bushes are solid except the rta bush. It's seperated from the outer metal ring and arm can move about. Well we'll see anyway ay. It'll be right before too long either way. Want it right for japshow that's my goal Link to comment Share on other sites More sharing options...
KiNK43 Posted April 8, 2012 Author Share Posted April 8, 2012 got the stuck lockring off today. unfortunately it broke.there was only a little white dust under it. but my god it wouldnt budge. i put it in the freezer. i tried penetrating oil 3 times a day for almost a week. still today i tried and tried with it in thevice and finally the ring just snapped. will try camskill see if i can get another on. fingers crossed! Link to comment Share on other sites More sharing options...
civicturbo79 Posted April 8, 2012 Share Posted April 8, 2012 At leasts its off now you im sure you will be able to get a new ring , make sure you grease the threads so you do not have this problem again in the future .Rich. Link to comment Share on other sites More sharing options...
KiNK43 Posted April 8, 2012 Author Share Posted April 8, 2012 At leasts its off now you im sure you will be able to get a new ring , make sure you grease the threads so you do not have this problem again in the future .Rich.Yeah should find one even if its not the same doesn't matter long as it does the job.I have greased up the threads on the ones I've fitted. Although once there set hopefully won't need to touch them.Cheers rich. Link to comment Share on other sites More sharing options...
KiNK43 Posted April 13, 2012 Author Share Posted April 13, 2012 Definately lower. I just piled front tow hooks into a speed bump I can normally bowl straight over Link to comment Share on other sites More sharing options...
