help needed with hid's
garyvtec
Ok the ovel bit in second to last pic goes into ballest
The 3 pin connector plugs into your car loom that plugs into normal bulb
Other small round connectors just connect to other bits that come off ballest
the test centre that i use are strict as hell so ill just through standard ones in for mot then put leds back after. hope i pass the only thing i think ill fail on is the handbrake being too slack so ill titen that tomorow. i tries getting the 2 screws out today to access the cable but holy turd they are well stuck
