vtismill Posted August 5, 2013 Share Posted August 5, 2013 Hiya I have a very annoying problem with my vtis at moment well it's been happening for a while nowBasically when the car is cold it holds back majorly when driving pretty much at any revs I'm any gear, holds back and slows down just backfires constantly then if I put foot down a bit more it clears but then will do it again just a few seconds later, when engine is hot it doesn't happen and it's always at like half throttle, still does it even with new engine although I did use my old dizzy? Could it be that? Leads? Ecu? I've no idea it's very very frustrating It's like it's over fuelling does it at idle too when cars not hot, any ideas please? Would be much appreciated thanks very much! 1 Quote Link to comment Share on other sites More sharing options...
simpo Posted August 5, 2013 Share Posted August 5, 2013 Firstly car will be sluggish if ur trying to rag it when it's cold as vtec doesn't work intill car is up to normal temp!Dizzy could be the problem but I would start by changing plugs and leads as its a lot cheaper than a dizzy Quote Link to comment Share on other sites More sharing options...
vtismill Posted August 5, 2013 Author Share Posted August 5, 2013 Cheers for the reply, car never gets ragged from cold never take it above 3k revs till car is warm and definitely don't take it anywhere near vtec! I've spent loads on this car and look after it well, It does it in all gears up to 3k revs so in 5th it will still do it even at 50mph, didn't word it very well, will try plugs and leads though cheers mate Quote Link to comment Share on other sites More sharing options...
aerodeckvtis2000 Posted August 5, 2013 Share Posted August 5, 2013 try p.m.ing dave the boss, he's got a full distributer . Quote Link to comment Share on other sites More sharing options...
Paulvti Posted August 8, 2013 Share Posted August 8, 2013 leads and plugs first if still no cure it'll be the crank position sensor or coil inside the distributor starting to fail,I would know I've had many fail in the past Quote Link to comment Share on other sites More sharing options...
vtismill Posted March 9, 2014 Author Share Posted March 9, 2014 Just an update on this in case anyone has has something similar, turned out to be the lambda sensor! runs so much smoother now Quote Link to comment Share on other sites More sharing options...
simpo Posted March 9, 2014 Share Posted March 9, 2014 Nice one mate glad you got it sorted Quote Link to comment Share on other sites More sharing options...
